rear drive shaft
Old 06-06-2009, 03:58 PM
ted
ted's Avatar
rear drive shaft
on long wheel based double cardan joint rear drive shaft trucks, is this necessary? I have seen same length truck without this.....
reason for asking is I am getting vibration on slightly hard acceleration from standstill (similar to uneven flywheel) , I had it turned already, replaced the clutch assy too.
the truck is a crewcab SFA hilux diesel (NON-US), rear is lifted to about 5", custom leaves, 2" longer shackles.... has degree shims that aligned the 3rd to the tcase good enough.
I am thinking that removing the double cardan/ the center-bearing(aligned too to match the lift) that holds it will get rid of the vibes.
help?
Old 06-06-2009, 05:49 PM
Fossilized
Staff
dropzone's Avatar
sounds like a plan getting rid of the carrier bearing and going to a one piece driveshaft.
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: rear drive shaft
