Rear Axle Seal/Bearing Job
I am finishing up replacing the rear wheel bearing and seals on my 87 Pickup. I picked up a new O Ring to install too - the one that goes around the end of the axle housing. I am wondering if I should also put some RTV around the rim or should that be avoided? Is the O-Ring sufficient? I didn't have any leaks previously, but can't tell if the factory added any gasket maker during assembly? Thanks a lot for any advice!
If you see any rust/pitting where the O-ring contacts the axle housing or the bearing pocket a skiff of RTV isn't a bad idea. It's probably not a bad idea either way. If you have clean surfaces then a good amount of grease would be a good alternative.
btu44
10-07-2016 08:03 AM
BattleWagonActual
12-26-2015 05:30 PM
Elow007
7
12-04-2015 02:12 PM
Superwhitetaco14
11-16-2015 04:30 PM
