rear alignment?
rear alignment?
So I been researching around and from what i been reading there is no alignment that can be done for the rear. Buuut... On my 91 4runner 3.0 I can notice that my driver side rear has a negative camber.. And my rear passenger side looks pretty straight up and down. Any ideas why?
Thanks
Thanks
Most shops give free alignment checks. Much more accurate than eyeing it. I agree with checking for play in the bearing. You hit anything? The only adjustment you can make is for the thrust angle. So either your eyes are off, or something is broke.
Havent really hit anything to think it could have been bent. How can I check the bearing? Do I just jack up that side and see if there's play in the wheel?
For sure I need an alignment but I am worried I am get an alignment and still wear my back tire.
On front tires, you often want a little camber, so you just tip the level until it's plumb, and estimate the distance from the tip of the screw to the rim. Use the formula to compute the angle in radians. (1/16" over 12" is 0.25°; you can measure with great precision)
Athansinis
07-27-2015 08:38 AM
icentropy
07-14-2015 10:23 AM
