Radiator Leak and Front End Vibration
Old 03-09-2014, 06:17 PM
toyoterferdayz's Avatar
I have been searching around yotatech but have not been able to find answers specific enough for my problems. I just got done replacing my head gasket. When the engine is running, the fan flings coolant around the front of the engine compartment. I can see some coolant escaping from the radiator cap. The surface where the cap seals against is very rough and looks all scraped up. Is there a way to replace just the radiator fill neck? The leak stops after a few minutes of driving so I am guessing that it is isolated to the top few inches of the radiator. anyone else had this problem?
On to my second problem. Now that I have been driving the truck, there is a front end vibration that I am having a hard time with. All the steering component are new and solid. Wheel bearings are good. It is a pretty high frequency vibration coming from the front passenger side. I am guessing CV axle but want to be sure because the boots and everything are fine so it's hard to tell. Also, when I put it into 4 wheel drive it gets much worse and sounds kind of like a chain saw is running underneath my truck.
All help appreciated, thanks.
Old 03-15-2014, 10:28 AM
Nobody feels like giving any info.... lammmeeeee
Old 03-16-2014, 11:46 AM
LITLRED's Avatar
I've had this a lot with rad caps. Is your radiator original?
Have you tried a new cap? Sometimes with aftermarket radiators you need to crimp down the tangs on the cap a little to get them to seal tight enough.
This cheap trick below really helps troubleshoot coolant leaks.
https://www.yotatech.com/forums/f116.../#post52142968
Old 03-16-2014, 01:34 PM
wyoming9's Avatar
Red face
Pretty hard to comment when you forget to mention just what your working on
22Rec engines are known for air pockets that will push out just like yours
Colington
03-08-2020 09:51 AM
Road Bull
10-10-2015 04:55 PM
Daneums
08-20-2015 05:36 AM
Avenged
07-09-2015 07:55 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Radiator Leak and Front End Vibration
