Quick release doors
Old 11-24-2011, 07:43 AM
rattlewagon's Avatar
Quick release doors
Ive gotten a couple PMs asking me how I did this so I figured Id just make a thread about it.
The short of it is that I cut the door hinges, tapped the pin out with a punch and put some 7/16th pins in place. I dont have electronics in the doos, which makes it a little easier. Ive heard of people using 4 pin trailer connectors for quick disconnect of the electronics.
On with the pics.
I pulled a hunge off my parts truck so I could test it before cutting the hinges on the truck.
Factory bottom, quick release on top.
Got my hinges finished up.
I remembered to charge my camera and bring it, however, I forgot my memory card in my laptop. F. So cell phone pics will have to do.
Had to grind a chunk out of the head of the pin to get it to clear the hinge bolt. Close up of the pin ground down clearing the bolt.
The view from inside. Should have done this YEARS ago.
So now when I make some half doors, I can switch them easily.
Thats all for now!
Old 11-24-2011, 09:06 AM
MP's4R's Avatar
How bout that brass bushing. Is there a replacement for that or alternative? I built half doors and want this for them, but when i built my set of hinges, i was unhappy with the play they had. I think it had to do with the bushing. It was like a brass wire mesh coated in rubber. Real flimsy. Would like a solid bearing/ bushing. But i havnt been able to find some with the right inside/ outside diameter combination.
Old 11-24-2011, 12:30 PM
scuba's Avatar
I use these weatherpack connectors from PCS for my wires running through my doors. Great quality.
Check with ace hardware.
There's actually a thread on here somewhere with that information.
You'll have to search for it though.
Old 11-24-2011, 01:40 PM
Zelephant's Avatar
What about the thingies that hold the door open on an incline? Do those just have to be disabled?
Old 11-24-2011, 02:34 PM
scuba's Avatar
All it takes to get off is a phillips screw driver. Takes 2 seconds.
Old 11-24-2011, 05:46 PM
Good point on those. Both of mine fell into the door, so watch out not to loose them.
Old 11-24-2011, 06:12 PM
WHAHAHAJR's Avatar
Where did you find the pins? Have not been able to find and at hardware stores but then again I may not of been looking hard enough.
Old 11-24-2011, 06:28 PM
Got them at ACE Hardware. Cost me $7 for all 4.
Old 11-24-2011, 06:39 PM
xxxtreme22r's Avatar
Tractor Supply company should have them as well. If those are the trailer safety pins that I think they are. I got one of those holding my hi-lift jack handle in place.
Nice work by the way. Gonna have to do this to mine when I find a place to get those bushings. Mine are shot.
Old 11-25-2011, 04:44 AM
WHAHAHAJR's Avatar
Thanks. I'll check it out.
Old 05-02-2012, 12:12 PM
AAAh what a great day to be doorless.
Remember to neversieze the pins to help them slide out.
Half doors coming soon...
suppra87
07-15-2021 05:15 PM
1uzRunner
63
11-10-2018 03:58 PM
old87yota
09-09-2015 12:39 PM
larrys93pickup
09-06-2015 06:37 AM
Quick Reply: Quick release doors
