Question about changing dash bulbs.
to start off I have a 1994 Toyota pickup 4x4,
Going to change all my dash lights and I need to know the total number of bulbs.
I want to replace every bulb from my cluster, behind my ac controls, and my inclinometer.
I have an sr5 cluster out of a 4runner, and the jdm inclinometer.
How many number of bulbs do I need to replace everyone in those 3 things.
Also, they're 194 bulbs correct? and the x74 hp3 for behind the climate controls?
Thanks!
I searched and only found partially of what info I needed.
and just want to make sure.
POSTED THIS IN THE ELECTRICAL FOURM, didn't get no responses
Thanks!
https://www.yotatech.com/forums/f116...l#post51402758
Here's part of your answer. I didn't photograph the inside of the A/C panel, etc. That is the easiest part of the dash to remove and put back, so it wouldn't take you 20 minutes to check the A/C panel for number and size of bulb(s) needed.
Check that thread link for other posts. There was some discussion about the total number of bulbs, though I don't remember if there was a definitive number stated. Buy 2 or 3 more bulbs than you think you need. That way, you should be covered in the event you didn't count them all, or you will have a few spares for burnouts.
ashersullivan88yota
01-18-2022 05:37 PM
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
icentropy
07-14-2015 10:23 AM
