Parts Truck
Staff
I have not swapped that generation of cabs but everything should except fenders and marker lights. They will interchange but the 2 wheel and 4 wheel is different from each other.
I just completed this same swap. check out my build thread.
https://www.yotatech.com/forums/f199...ebuild-297267/
Other rumors are that the cab mount height are different, they are not, they are the same. Also heard the shape of the inner fenders are different, not true, the inner fender I cut off my 2wd is the exact same as the one I welded on from a 4wd.
Just put the two cabs side by side and swap over anything that is different.
Note that the wiring harness will most likely be different in some way, so pull the dash, and pull the harness, swap over to the new cab. It will all bolt up exactly the same.
Ian
Nope, I just completed this same swap. Even the wrecker told me they were different, but this is the third time I have used a 2wd cab on a 4x4 truck. Call cabs are exactly the same. Even in the 2nd gen. I have even swapped a 1983 Xtracab 2wd diesel automatic onto my 22RE 4x4 5spd. Only modification you will be required to do is to change over the e-brake cable on the cab as 2wd and 4x4 are different. Fuel lines on my 1989 had to be changed as there was differences but i think that was due to difference in year not 2wd vs 4wd. Also, you will need to cut the hole for the shiftier larger. to fit the t-case shifter.
oh WOW
Excellent info
(tho Im not sure if this implies that you can use a Gen3 2WD cab (aka 1993) and bolt on the doors and fenders and make it an Gen2 body (aka 1988))
Excellent info
84YotaBuck
26
03-12-2018 12:10 PM
FS[MidWest]: Parting out 89 pick up with 3VZE (SHORT TIME ONLY!)
Crazychris1871
09-08-2016 11:17 AM
Charchee
07-31-2016 09:26 PM
10ac
07-25-2016 07:44 PM
