P/S idle up solenoid
i dont mean to thread jack, but is this what you guys are talking about? its on a 22re though. stolen picture courtesy of one of 4crawler's posts.
if not, what is this called? and how do i know if its adjusted correctly? i cant seem to find any specs in my fsm.
that wouldn't be the P/S idle up valve on the 22re Bryan. On both vehicles they would be right on the P/S pump. Not sure what that is, I'd have to look at a few drawings, but I wanna say A/C idle-up.
P.S. Whenever I go to a junk yard, I always grab these kinda things, way pricey new and most pick a parts around here don't even charge ya for em. That little 3-way (gas filter) vacuum port is another one of those things that like to break. Most people are willing to pay $15-25 on these things.
on my truck the vaccuum lines attached to that thing i circled go straight to the power steering pump. whether that is wrong or right i do not know. i am going to start tacking a small idle issue i have and just want to id everything that may be a possible cause first
i checked with toyotapartszone.com and found a picture of it, but no part number is associated with it. it is a supplemental drawing for trucks that had the power steering cooler stock from the factory, which i have.
here is the drawing...
anybody??
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
anybody??
And if you turn up that idle speed too high (above around 1200 RPM), you'll hit the brake cut point in the ECU. If you tap the brake pedal, the ECU cuts fuel to the injectors if the idle speed is too high.
4crawler,
if its for the ac, why does is plumb down to the power steering pump?
i dont think mine is plumbed wrong either cause the toyotapartzone diagram i linked to above shows it going to the power steering valve thingy part number 17630.
See:
http://www.4crawler.com/4x4/CheapTri...ine_Pix/7.html
It is for both power steering (p/s) and A/C, has two ports on it, apply vacuum to either port and it'll feed more air into the intake manifold and increase the idle speed.
P/S valve is actuated by fluid pressure inside the p/s pump, the A/C VSV is electrically actuated when the A/C compressor is running. Back when I had the stock p/s pump, I found my vacuum port feeding that valve was plugged with carbon so never did work. Cleaned that out and noticed no difference in operation and since I have put in a different p/s pump, I have not had that valve at all and really do not miss it at all. If I need a little more p/s boost at idle, I just tap the gas pedal a bit.
hmmm don't remember that on the 92 I pulled my system out of, could have swore the vac lines from the pump were plumbed either directly into the intake or the throttle body.
