Not sure exactly what it is, but something doesnt look right
Old 06-16-2008, 10:14 PM
t0mwat3r's Avatar
This is the passenger side, does this not look right?
this is the drivers side
Old 06-16-2008, 10:16 PM
Staff
DeathCougar's Avatar
Thats def bad. You need to replace your idler arm ASAP.
Old 06-16-2008, 10:33 PM
Ezrider_92356's Avatar
i wouldent say asap, i would say before you drive the vehicula even 1 more time, that is an accident waiting to happen
Old 06-16-2008, 10:42 PM
t0mwat3r's Avatar
but the drivers side is fine correct?
Old 06-16-2008, 11:37 PM
stormin94's Avatar
Nope, looks good to me.
What exactly are we looking at?
Old 06-16-2008, 11:42 PM
t0mwat3r's Avatar
Old 06-16-2008, 11:48 PM
stormin94's Avatar
Ok, on second thought, you should probably replace that part as soon as possible.
Old 06-16-2008, 11:56 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Holy schmidt! That thing is shot! After you replace it, get your alignment checked. You might also wanna check your tie rod ends and see if any of those are bad.
Had any accelerated tire wear issues, lately?
Old 06-17-2008, 12:06 AM
t0mwat3r's Avatar
i haven't had any abnormal tire wear, So to fix this problem i would need to replace my idler arm and have it aligned?
Old 06-17-2008, 12:20 AM
Jay351's Avatar
YES! Replace the idler arm asap, looks like the stud is gonna pull right out of the arm.
Old 06-17-2008, 12:26 AM
thook's Avatar
It already has! All it would take is just enough droop on that side to totally displace it. Eeeek! is right!
Old 06-17-2008, 02:16 AM
SwampThing's Avatar
Pfft. Who needs idler arms. SAS that beast!
Old 06-17-2008, 02:17 AM
SwampThing's Avatar
At lease, that's the argument I'd use if I wasn't in control of my own check book
Old 06-17-2008, 02:35 AM
Offie's Avatar
Wow, that really looks bad, I bought this set on ebay, good quality.
about 3 hours and it's all new
Old 06-17-2008, 03:33 AM
mt_goat's Avatar
Don't drive it! Call a tow truck if you can't replace it yourself. BTW there is a recall on the center link thingy. https://www.yotatech.com/forums/f116...8-t100s-66901/
Old 06-17-2008, 03:59 AM
Lysmachia's Avatar
X2. How much lift do you have? If I understand correctly a lot of lift with IFS can cause Idler arms to fail often. Once you get a replacement, I think you can beef it up by getting a brass bushing set, though they often have to be machined once you get them to fit right. TC knows more about this than me so maybe he'll chime in.
Old 06-17-2008, 04:59 AM
toytech76's Avatar
I totally agree, replace ASAP. As for the recall, its only 89-95. His looks to be pre 89
Old 06-17-2008, 08:29 AM
mt_goat's Avatar
Oops, my bad.
Old 06-17-2008, 08:40 AM
Chuckracer's Avatar
Idler arm swap won't affect the alignment.
Old 06-17-2008, 09:27 AM
spdjnky's Avatar
Looks exactly like mine did! At the time i had no lift at all. I found mine when doing a routine check and had no idea how long it had been like that before I noticed...probably 2-3 weeks? thankfully I had a spare and replaced it that night.
I agree with Chuckracer, replace and no need for alignment.
