New owner with window switch issue
Hi all,
I am new to the pickup forum. I have just purchased an 86 xtra cab 4X4. The power windows won't function with the main driver door switch, but when direct power is supplied to the connector, they work. Bought new switch, and still don;t work through the switch Suggestions?
What connector?
A problem well-stated is a problem half-solved.
Concur. (See signature re: multi-meter)
Why did you replace the switch?
Switch is new out of the box. Figured it was the switch since I could unplug it and power the windows from the connector that plugs into the switch. The switch lock button locks the doors, and the driver window down when pressed unlocks the doors, Will have to start looking for a short and clean the connector I guess.
Mine quit working. I haven't got into it yet. But My truck alarm would lock the doors and roll up the windows. It got wet and has not worked since. I suspect its the problem
jasonty
41
12-23-2018 01:00 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
Johntom240
7
07-13-2015 12:18 AM
