New noise, 89 22re, sloshing/whisking?
Well at a stop light today I noticed a new noise coming from the 4runner. It sounds like *slosh-slosh-slosh-slosh*(sort of), is matched to the rpms of the motor, doesn't do it all the time but it's doing it a little more tonight than it was this afternoon and seems to be coming from the 5 speed tranny. I would suspect throw-out bearing but was told it was replaced (yeah, I know). The tranny has gotten harder to get into gear in the last few weeks if that helps at all.
Thanks.
Thanks.
No way to even take a video, and no the truck didn't make any noise at all. Stop saying things like that or I'll do a 180 and sell the 4runner..... you're just trying to confuse me.
Doesn't matter if the clutch is in or out, in gear or not. If I could get it to make the noise when I'm at home in the garage I could probably find it. So far it only does it when it wants to and I guess it just doesn't want to make noise when I can look for it. I swear 1st gen runners are like children.
update
Okey dokey. I have an update.
It now does it almost all the time. At a stop light a little while ago it was really apparent so I went down on the shifter and put my ear to the top of the stick (like you would when using a ratchet extension to listen to the drive train) and I could hear a rotating noise as well as what sounded like the gears spinning. Ok the noise will stop as soon as I put the rig in gear and ease out on the clutch.
I've priced a clutch kit (clutch, pressure plate, TO bearing, pilot bearing, install tool) and although it's a bit pricey I think I can afford it just as long as I do the install myself. Yeah that's going to be a long @$$ weekend of dropping the tranny and all.........
It makes the noise all the time (clutch in or out doesn't matter) up until I ease up on the pedal with the rig in gear. A soon as there is resistance (the rig begins to move/you can feel the motor starting to engage the tranny) the noise goes away.
Jeffreynmandy
07-18-2015 08:26 AM
