Needing to replace front leaf springs
Old 04-21-2015, 03:30 PM
Crazy_Guy97's Avatar
Im wanting to replace my front leaf springs on my 1994 Toyota 4x4 straight axle they're 47'' inches long by 3 1/2 inches wide .Where would the best place to get a set? Can I use 2wd leafs springs or do i have to use 4x4 leaf springs?
Old 04-21-2015, 05:28 PM
osv
osv's Avatar
i think that i'm running toyota rears up front, which is ~46" long at ride height, measured straight across, so it's probably about the same length as yours.
however, i think that my springs are only 2.5" inches wide, so if you are at 3.5" wide, is that a toyota spring setup?
maybe it's chevy springs, so a trip to the chevy truck junkyard is in order?
Old 04-21-2015, 11:58 PM
wyoming9's Avatar
Red face
Be nice to know just what they came off.
I am guessing you did not do the SAS .
Do you want to go with new springs ??
A set of used springs of unknown vintage??
I did used springs long ago one was good the other once installed with weight was flat .
Off the vehicle they both looked the same.
General Spring hasa great web site for leaf spring dimensions
Old 04-22-2015, 11:25 AM
highonpottery's Avatar
you should also be looking for some front shock towers....
Old 04-24-2015, 05:34 PM
Im going to make the shock towers .
leafsprings_sux
06-26-2015 12:55 PM
dirtrider0129
10
06-24-2015 12:24 PM
TheManOutside
06-18-2015 03:32 PM
Paul S
06-20-2002 05:07 PM
Quick Reply: Needing to replace front leaf springs
