Need some help
Need some help
So ive been doing the sas swap and i ran into a issue with my shackle angle. i burned the crossmember in and my angle was not good at all so im on try #2. Im goin normal 4"tg springs 22re 4 cyl motor no plans for anything heavy up front(winch ,etc).i would like to know what angle i should aim for with just the hanger and springs attached. Like 60 or 70*??
I understand every truck settles different, im just trying to get a ballpark so im not doing all the extra work. Heres what i mocked up real quick before it got dark
How far forward is the front hanger?
Right now I think you would lucky if they settled enough but don't think it would be likely.
There is a copy of a quote by ScottyC (addicted off road) in my Mini FAQ thread on front hanger placement for proper hanger placement with each spring height
see link in my sig
What model/year truck?
see link in my sig
The hanger right now just clamped is about flush with the existing its kind of hard for me to tell since my crossmember is tubing i had to weld in my old one was rotting out. The reason i cant follow the instructions from ur faq is since my shackle tubes are foward all the way. It would be a pita to move them now just trying to get my placement good before any weight is on the springs
