Need help replacing front lug studs
Old 11-14-2011, 06:24 PM
22repower's Avatar
My valve stem was leaking so I took my 93 to my buddies house to get her fixed, got that fixed and went to put the wheel back on and BROKE 3 STUDS IN A ROW!!!! One with the impact and two by hand. The other three didn't get cranked down after that, so now it's stuck about ten miles from my place.
So I find this thread
https://www.yotatech.com/forums/f116...-stuck-195351/
WOW.... This doesn't look like fun
What do you guys think I should do
Old 11-14-2011, 06:26 PM
waskillywabbit's Avatar
I'd get six new wheel studs and replace them all while you are there.
I'd check the rest too.
:wabbit2:
Old 11-14-2011, 06:39 PM
22repower's Avatar
Yea I know they'll have to be replaced
I was hoping you guys might have some tips to chime in
That other thread makes it look way harder than it should be
Old 11-15-2011, 06:27 PM
22repower's Avatar
Tore into it tonite
Here I got 4 out of 6 cone washers out from about 50 hits apiece with a hammer and screwdriver
Took a little break, pryed the gaps, and with about about 100 more taps each got the last two
12mm bolt, snap ring, and 54mm (i think) nuts came off fine
I had to unhook the brake line because it was hard line, but the caliper came off without a hitch, and now were bare!
Got everything separated, now I just need to pick up some studs tomorrow....
And at least I know why they broke:
Is it normal for those to wear like that? I'm assuming they are the originals from 93
One last thing, the one on the right came out of a 94 and seems a bit thicker than the ones that came out of this truck, is that right (the 94 was built in japan and 93 in US if that matters)
Old 11-15-2011, 06:32 PM
22repower's Avatar
Also, how do I go about torquing the preload on the inner nut and lock nut, and the washer that goes between them
Old 11-16-2011, 06:10 AM
22repower's Avatar
Anyone?????
lledwod
08-30-2016 01:03 PM
ItsJustD
07-07-2015 07:49 AM
Jnkml
07-06-2015 01:20 PM
toyoda8488
07-05-2015 10:18 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Need help replacing front lug studs
