Need help installing a Tach
Old 11-21-2009, 05:32 AM
jamarak's Avatar
I ordered an Autometer Tach. Does anyone know how to wire it to a 1988 Toyota 4runner with the 22re? Any help would be great. Should I wire it to the ingnition coil or somewhere else? Thanks.
Old 11-21-2009, 06:15 AM
Built2Grind's Avatar
you need a spot for a wire on the negative side of the coil, a wire for power, a wire for the backlight(usually hooks into your headlight switch). and of course a ground. i bought an equss tach a while ago and the diagram says. Red wire to +12v through your ignition switch(fused). white wire to +12v through headlight switch(fused). black wire to a ground. and the green wire to the negative side of your ignition coil(not fused). hope this helps
Old 11-21-2009, 06:44 AM
jamarak's Avatar
Thanks for the help. I will hopefully be able to get this done this weekend.
Old 11-21-2009, 10:09 PM
cody_brush's Avatar
post some pics of the install if you can
Old 11-21-2009, 10:27 PM
Tracey98277's Avatar
dude... it comes with instructions, its gonna be ok.
nvdesertrunner
05-11-2020 08:18 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
94ofCanada
08-14-2015 06:37 AM
altydog
07-28-2015 10:20 AM
Quick Reply: Need help installing a Tach
