need help identifying wiring plugs '91 22re
Just finished doing a head-gasket on my truck and am having trouble finding where a few of the plugs connect too
truck is '91 22re w56
although im finding some of my parts i have to get from a later truck, such as my coil/plug wires have to be from a '93 style with the smaller clip on style wires. So im not sure if the previous owner swapped motors or transmissions everything seems factory..
The plugs on wiring harness i cannot find.
#1 near the back of intake manifold i have this one with one blue wire and one brown. im not seeing where it would connect to .
#2 near the transmission . It is pretty long and and i see no where for it to connect either.
My backup lights are not working but i think i have those connected right, im thinking the wire is broken right at the connector for that where it looks kinked.
thanks, It looks like you are right.
I have no ac so the plug is just extra .
My speed sensor in the transfer case had been swapped over to the mechanical cable type to be compatible with my dash speedometer .
I noticed the plugs seemed dirty inside the connector so I thought mabey they were never connected but wanted to be sure
Thanks again
Thanks again
steve miller
10-10-2015 01:40 AM
