My new 22RE
My new 22RE
Here goes:
My 89 yota started running bad & leaking oil from the head gasket at around 154k. I pulled the head and discovered a broken head bolt & the lower end looked in bad shape.
New motor time! Or new truck time???
I decided to go the new motor route. After some research I decided to get the following parts:
LCE shortblock
ENGNBLDR street/RV head with 268 cam
LCE header
LCE rocker arm assembly (actually cheaper than dealer`s quote of 600!)
new radiator
new o2 sensor
I`m building this primarily as my dailydriver, but I plan on going through the truck a bit at a time. All of the parts for my motor got here yesterday, although it will take me a bit to have a space available to do the work. I`m looking forward to this, as I have never really put together a motor before. Anyways, I will be under the direction of a solid mechanic with a decent shop.
I have heard mixed reviews about adjusting the AFM to enrichen the mixture, and I would like some of your thoughts. I live at & play at high altitude (7,000+) anyone with some experience on that mod?
Anyways, there`s my first post....
LCE shortblock
LCE header
new radiator
new o2 sensor
I don't think you'll have any AFM adjustment issues with the cam you chose.
Also, at high altitudes, air pressure is less so adjusting for more fuel would be a bit pointless. The AFM and O2 sensor should be able to keep the mix pretty accurate. If anything, you may have to lean the mix a click.
But I digress---- good luck!
TAKE LOTS OF PICTURES!!!!
...and make sure you've got something to celebrate with when it fires up.
Here it is, finally put together, didn`t go for the bling valve cover, but cleaned mine up. All EFI stuff will be at factory specs, & I need a new O2 sensor. This book from LCE had a butt-load of info in it.
This motor is equal to 14 days of 16-hour shifts firefighting in Norcal this summer (about $3200, with header, radiator, o2 sensor, beer, headbolts, rocker arm assembly & belts, hoses & whatnot...)
It`s so pretty & shiny, I feel like I should buy the motor a beer because it looks so damn cool & I learned a bit more about engines & building them. Anyways, more pics to follow later this week.
Before:
After:
Well, looking back I could have done a 3.4 swap, but I wanted to keep my truck more or less stock for parts & service in the future. So here is my finished motor! The biggest issue was getting the header & o2 sensor mount thingy to line up. Nothing a little heating & bending couldn`t fix though...
This thing absolutely purrs, and seems to have much more noticeable power. It would be nice to get it on the dyno in Phoenix after I get it broken in. I left out the old AC stuff, it never really worked & was the old style that needed to be converted. Besides, it is rarely needed at 7,000`! This spot is now reserved for my York compressor..
Header:
I will say that I had top-notch dealings with LCE & EB, and I reccommend them to anyone.
After:
Header:
If he was going to go turbo he should have spent less on the rebuild in my opinion. LC engineering is ver proud and there prices reflect it. I dont doubt that you get a great product but its still major coin. I would have gone engine builder kit, done the work myself if I was planning to turbo it.
TOO LATE!!!!
I don`t plan on a turbo, just a solid motor that will get at least another 154,000. There may have been cheaper ways to rebuild my motor, but since my old head was warped & the bottom end seemed in pretty rough shape
I didn`t have much choice other than to go with a new casting.
Again, in defense of LC`s prices, there rocker arm assembly was cheaper than the Toyota dealership. I could have purchased a complete Jasper longblock for around 2,000, but I didn`t want a Walmart grade motor. A friend had a used 22re with 30,000 on a rebuild, he wanted 1,000 for it, but it hadn`t run in a year and was out of a vehicle.
I have been at the mercy of several Flagstaff mechanics before and having learned my past lessons from the "tourist-trap" mechanics & machine shops here, I opted to spend a little more money on higher-end stuff rather than get royally donkey-punched again.
I had the guidance from a good friend & mechanic here who reccommended that I get all machine work done in Phoenix at a reputable shop, if I stuck with my old block, but he believed my old motor was too far gone for a rebuild.
As far as a turbo, I can still go that route although my compression is 9.5 to 1, which may be a little high for any real boost. Personally, I am just happy to be able to DRIVE MY TRUCK AGAIN!!!
Thanks to all of you who provided some input & insight, and I look forward to asking more questions about future mods.
