Is it my head gasket or something else?
Old 02-19-2010, 06:26 AM
shortwing's Avatar
I have a 1987 22RE that was rebuilt about 18 mounths ago by a local shop. There is no water in the oil. Nice clean oil. 160 lbs of compression on all 4 clyenders. No bubbles in the radiator when warm and ideling with the cap off. It runs strong down the freeway at 70 mph.
But it just started smoking like a fiend, radiator water is going away and water is almost running out the exhaust. The exhaust water smells like coolant.
Steve
Old 02-19-2010, 06:52 AM
snobdds's Avatar
Do a leak down test. It will tell you if it's your head gasket or not.
Old 02-19-2010, 07:11 AM
shortwing's Avatar
Sorry, but what is a leak down test?
Old 02-19-2010, 07:15 AM
mightymouse's Avatar
go back to the local shop and ask them to fix it.
Old 02-19-2010, 07:17 AM
mastacox's Avatar
If you're burning that much coolant, it's the head gasket. Sorry.
Old 02-19-2010, 07:33 AM
shortwing's Avatar
so I searched leak down test and know I know.
Old 02-21-2010, 12:17 PM
Chuck Manners's Avatar
its eaither a head gasket or an intake gasket
Old 02-21-2010, 12:35 PM
87toyy's Avatar
i had the same problem on a 22r carbed and a 22re. theres a small plate on the back of the head it has i around 4 bolts holding it on. it was the gasket on that was gone on both of mine. seemed like the coolent was basically pouring out the exhaust. once i fixed those gaskets no more smoke or coolent loss on either motors.
Old 02-22-2010, 07:06 AM
shortwing's Avatar
I pulled the head, no obvious leaking. The gasket had a defect at the cylinder edge beside a water passage. The bolts were not all that tight, but they were not lose. The water was only going out the #4 cylinder. Some signs of combustion gases leaking between 1 & 2 and 3 & 4. The head was not even stuck to the block. Good machine work where the block was decked and the head was straight.
I think the shop used a poor quality gasket to save a little money.
Old 02-23-2010, 03:49 PM
snobdds's Avatar
I always use OEM toyota head gaskets. There $47.00 and in the long run, it will save you money over that cheap junk.
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
themightykhoner
08-11-2015 07:37 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Is it my head gasket or something else?
