My First time. 91 yota 22re.
Okay this is my first truck and i can tell engine has taking beating over the years so i decided i wanted to do some upgrades now note that i only make 300 on average weekly but really this truck is my only bill for now.
so overtime this is what i wanna do.
Rebuild
http://www.lceperformance.com/Produc...10006&CartID=1
Cooling
http://www.lceperformance.com/Produc...93063&CartID=4
http://www.lceperformance.com/Produc...93131&CartID=5
http://www.lceperformance.com/Produc...93018&CartID=3
http://www.lceperformance.com/Produc...32070&CartID=6
then add a little performance to it.
http://www.lceperformance.com/Produc...61508&CartID=8
http://www.lceperformance.com/Produc...41030&CartID=7
http://www.lceperformance.com/Produc...42000&CartID=2
now is there anything i should know expect to walk into or need when rebuilding this truck?
it is a 1991 toyota 22re with no rebuild ever 180k+ Miles ( speedometer/odometer cable was ripped when i got it ) i know the timing chain is bad and i think the valves need to be adjusted.
but does this all seem okay to do?
will i see a big difference?
any experience with this field?
anything would be nice to hear advice , idea's , suggestions and experience's
Rebuild
Cooling
should i go ahead and replace any hoses/o2 censors? or anything of that sort?
the truck has already seen a full tune up
-PCV
-Plugs
-Wires
-Cap/rotor
-Oil change
-Air filter
-new fuel pump/tank/cap
-new radiator cap
-PCV
-Plugs
-Wires
-Cap/rotor
-Oil change
-Air filter
-new radiator cap
https://www.yotatech.com/forums/f120...-cheap-257582/
Here's a good thread, don't know if you've seen it.
