My auto shifter is not shifting!!! HELP! PLZ!
Hi Yotatech,
93' Auto, V6
Yesterday I was leaving for work and my shifter would not go into drive, or anything else. I stepped on the brake with the car running and the button on the shifter would not push in. Thankfully Toyotas have the "shift lock override" button...
Is there a linkage between the brake pedal and the shifter? I tried searching with no luck.
Thanks in advance.
93' Auto, V6
Thanks in advance.
^X2, the same thing was happening to me last week. I was blowing fuses like crazy. I ended up having a short in the trailer light harness from it rubbing on the frame.
I don't have any blown fuses.
Would a short in the brake lights cause the auto shifter to not go out of park?
unless I push the shift lock override button, I cant shift from Park to anything else...
It keeps you from driving around without brake lights.
Astralplane you are awesome!
It was the "STOP" 15A fuse...
I will get a new one tomorrow and hopefully that will fix it...If not Ill be crawling around under it this weekend
FS[PacNorWest]: Really Nice Truck on WA craigslist
Esibnitsud
07-21-2015 08:51 AM
crashburnoveride
07-10-2015 06:39 AM
