My 22RE won't hold between 1200 & 1800rpm???
Old 02-24-2010, 12:31 AM
Subaru4WD's Avatar
Ok... this is wierd. Im not sure where to start troubleshooting.
My 22RE runs great! I love it. It idles great at 950rpm. It starts up, and runs great no matter what angle I drive. When I accelerate, it accelerates smoothly and with alot of power.
However, when I am crawling, it won't hold any RPM below 1800rpm. If I feather the throttle, I get no response, and then all of a sudden it shoots to about 2200rpm. And if I let off alittle, I can get it to hold about 1800-2000rpm... but if I try to get it any lower, it elopes. When I say elope, I mean it goes from idle, 900rpm, to 1600rpm, and then back to 900 rpm, and then 1600rpm... until I increase the throttle, or let off completely.
I know my 4Runner was converted from an Automatic to a 5spd by the previous owner, and I am wondering if maybe there is something that needs adjusted... or maybe something that has been overlooked.
My other car is Carburated, and I am not extremely familiar with Toyota's EFI setup.
Thanks in Advance,
-Brian
Old 02-24-2010, 12:08 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
And the CEL is not on, correct?
My 1st thought is computer...EDIT: or O2 sensor... But it's prolly more simple than that. I'd inspect it really good for loose connections and vac lines that could be off.
EDIT, EDIT: and self duh! The TPS... ohhh, Rodger!
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old 02-24-2010, 07:24 PM
Subaru4WD's Avatar
Thanks man. I suspected the TPS but I didn't know where to find the procedure for testing it.
That website is awesome!! I'll pull out my Multimeter and get to testing.
Thanks again
Old 02-24-2010, 07:32 PM
myyota's Avatar
Pull the throttle body off the intake and give it a good cleaning, and then make sure the TPS is properly adjusted.
Old 02-25-2010, 12:05 AM
abecedarian's Avatar
Let's start of with saying that a 22re should idle around 750. So set your base timing around that, please. While you're busy setting your timing, the TPS should be set properly too.
Old 02-25-2010, 12:09 AM
Subaru4WD's Avatar
Thanks, im going to tear into it this weekend. I also have to figure out how to mount my York compressor and it looks like I will be pretty busy
icentropy
09-16-2020 02:47 PM
Doug4320
03-24-2018 10:11 PM
RatOmeter
10-22-2015 03:17 PM
ty1er
07-19-2015 06:42 PM
shisha1999
07-13-2015 11:09 PM
Quick Reply: My 22RE won't hold between 1200 & 1800rpm???
