More broken IFS garbage
Old 10-27-2008, 10:34 AM
Beaniam's Avatar
This weekend claimed the passenger side axle/cv stub.
Check it out
(good spare on left)
Luckily it looks like the lockright splines aren't damaged. Not sure how but it seems the stub came out about half an inch, rounded off the splines then cocked itself sideways. Thought I blew the hub when the right front wheel went dead until I looked under and saw gear oil leaking out and the stub sticking half way out and at a 45 degree angle. The c-clip was still on it and appears to be undamaged. The CV isn't broken or siezed either. I have to play nicer with my locked IFS.
Old 10-27-2008, 10:36 AM
just a 22re's Avatar
ouch that sucks man good thing nothing else was bad when it went on ya never saw that happen though
Old 10-27-2008, 12:35 PM
tc
tc's Avatar
Something else must have been seriously wrong for that to happen!
Old 10-27-2008, 12:39 PM
saitotiktmdog's Avatar
That looks like muddy water in your diff. That cant be a good combo.
Old 10-27-2008, 01:37 PM
iamsuperbleeder's Avatar
I was about to say, that's some nice looking gear fluid
Old 10-28-2008, 05:15 AM
gte718p's Avatar
What are you using as oil pond water?
Old 10-28-2008, 06:33 AM
Beaniam's Avatar
Well obviously there was a big gaping hole after the axle stub came out halfway as the seal wasn't touching anything anymore so there was nothing stopping water from coming in for the remainder of the day while I 3-legged it home.
Old 10-29-2008, 07:59 AM
What kind of snorkel are you running. Need one myself.
Old 10-29-2008, 03:42 PM
elripster's Avatar
Axle slipping out? Looks like that's what caused the failure. Notice the teeth are sheered off the end. Maybe the c clip wore out letting the axle slide some and that sheered off the outer most teeth.
Oh well, that's wheeling.
Frank
Old 10-29-2008, 04:26 PM
Beaniam's Avatar
Frank
Yeah that's what happened. At least I had a spare axle stub. Only gotta hold up another couple months until the SAS. I run an ARB snorkel with a Donaldson filter cap.
ladybugRC
458
08-21-2020 10:41 AM
punks_is_4x4
02-26-2016 04:29 PM
dirk89
10-01-2015 05:15 PM
bradahman
10-01-2015 09:24 AM
Brodetski
09-30-2015 11:50 PM
Quick Reply: More broken IFS garbage
