Metal in rear diff
Old 03-21-2014, 02:44 PM
hangtown88toy's Avatar
Metal in rear diff
Have 5:29 gears with a Detroit locker. I just changed the gear oil and the drain plug was covered with metal some chunks too. What would cause this and how can I prevent it. It is my daily driver too. Maybe that's why??
Old 03-21-2014, 02:57 PM
buickid's Avatar
Who set up the gears? If they were setup and broken in properly, there should not be chunks of metal in the oil. Some metal "sludge" on the plug is to be expected, but definitely not a lot, and not chunks. You might want to pull the 3rd member and check the ring & pinion for visible damage. Any strange noises? Not really much you can do beside making sure the gears are setup properly, and following proper break in procedure. Obviously you want to have a quality oil in there, but for most normal uses, unless you're using something really odd, gear oil is gear oil is gear oil.
Old 03-21-2014, 05:33 PM
rattlewagon's Avatar
Agree with all of the above. Absolutely pull the 3rd and see whats going on. Define "chunks of metal" did they look like bearings or gear teeth? locker pin or spring maybe?
Old 03-21-2014, 05:40 PM
Cyberman's Avatar
In the same boat right now. 5.29 gears put in over a year ago. Had a noise under load, but nothing coasting. Some metal on the plug. Pulled the 3rd and the pinion was chunked apart. No pinion bearing preload, and can turn the carrier adjusters with my fingers. Definitely not setup correctly.
Old 03-21-2014, 11:05 PM
More like shards of metal about 1/4" long I bought it used and when I installed the 3rd it looked fine. I use the correct gear oil . When I'm at a stop and I go to let the clutch out just a little I sometimes hear a thud. I'm sure it's the rear end but I'm not sure what's causing it
Old 03-22-2014, 01:43 AM
scuba's Avatar
That thud is most likely the locker engaging.
Metal shavings are okay and normal.
Metal chunks are not okay.
Old 03-22-2014, 03:08 AM
Fossilized
Staff
dropzone's Avatar
takes 45-60 minutes to pull the third...pull and examine it
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
scottyg486
07-19-2015 05:34 PM
kvanzandt1
07-18-2015 10:15 AM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: Metal in rear diff
