Look what came out of my fuel filter
Old 03-01-2009, 08:43 PM
91Toyota's Avatar
Lifetime huh?
Old 03-01-2009, 08:46 PM
littlecommando's Avatar
eww, did you flood your engine recently?
Jay351's Avatar
Yeah, when I got mine from the dealer the tech was like.. hmm they say its a lifetime filter.. Im like. No, there is no such thing as a lifetime filter.
too bad the lines on mine are rusted and stripped. Some doofus tried to use vice grips or something on them..
Old 03-01-2009, 08:49 PM
91Toyota's Avatar
lol...the tags on the truck say like March 2001 Its been sitting for a LONG time. I put 5 gallons of fresh gas in it and it ran "marginally" okay. Wouldnt go over 30mph though. I drained the gas tank already, and I'm in the process of swapping injectors and cleaning the intakes (both pieces!)
But no, I did not flood my engine
Old 03-01-2009, 09:02 PM
myyota's Avatar
Thats should be very good evidence for some people on here that think the fuel filter on our trucks is a life time part, ITS NOT.
Old 03-01-2009, 09:03 PM
91Toyota's Avatar
Yeah, I thought it was life time and did not replace the one on my 2wd
Old 03-01-2009, 09:05 PM
toyospearo's Avatar
Oh man! I think I need to change mine.
Old 03-02-2009, 01:53 AM
Guest
dport's Avatar
Should I punch myself in the face b/c I've had a new fuel filter sitting in my garage for a year now?
Old 03-02-2009, 05:36 AM
874runnersr5's Avatar
same.. i really need to get mine done
Old 03-02-2009, 06:01 AM
nosfanatic2006's Avatar
Fuel filter is always on my list for first things to do when I buy a used vehicle
Old 03-02-2009, 06:49 AM
how do you change it?
Old 03-02-2009, 06:55 AM
904_runner's Avatar
undo the lines on each end, remove old fuel filter, put new one in and tighten lines.
What motor do you have?
Old 03-02-2009, 06:58 AM
DupermanDave's Avatar
Step 1: Remove the engine
Step 2: Locate fuel filter
Step 3: replace
Fuel filter on the 22re, at least, is a pain to get to. I've been told you can access it from the passenger wheel well...but I didn't see a way to do this. I replaced mine while the head gasket was off. This is most likely not a 15 minute project and should be saved for a weekend project if you have other things to do on the engine.
Old 03-02-2009, 07:25 AM
Evil.Dingo's Avatar
Best time to do it is either during a clutch replacement, or head removal. The filter is located above the starter, under the intake assembly, behind alot of hoses and stuff. Royal pain to get to.
I replaced mine last fall when I did the clutch, 167,000 miles on the o.g. and it was fairly clean, but I'm glad I replaced it.
Old 03-02-2009, 07:34 AM
Windsor's Avatar
Yeah, that's why mine isn't done yet. I bought a new filter shortly after buying my rig and then later found out where it was hidden.
Old 03-02-2009, 07:37 AM
lol.
I love the way the Suzuki sidekicks have them. They are right in front of the gas tank and changing the fuel filter is a 5 minute job. Of course, when I changed it it turned into 15 minutes because I had to clean up after i got sprayed in the face with gasoline because I forgot to remove the battery cable and relieve fuel pressure in the system.
Old 03-02-2009, 07:39 AM
TOYOTA 1's Avatar
i can do mine in about 15min's lol.
i love my body lift
Old 03-02-2009, 07:58 AM
904_runner's Avatar
I ask what motor it is because that will allow us to tell you where the fuel filter is located.
On the 3.0 assembly. the fuel filter is located on the inside of the frame rail right near the passenger side torsion bar adjustment.
Not exactly sure on the 22re location.
Old 03-02-2009, 08:03 AM
so if i were to do it this weekend, what should i be aware of that can break?
Old 03-02-2009, 08:15 AM
PCE91V64x4's Avatar
you will want to consider having the hard lines on either side to replace as well as the fuel pump bracket since that probably should be done as well.
Quick Reply: Look what came out of my fuel filter
