lets talk 22r timing
Old 08-23-2012, 03:38 PM
my 75 toyota's Avatar
On my 87 pickup with a 22r engine. I just rebuilt it with the ENGBLDR kit and RV cam. So i have read that a 87 model year with a manual timed at 0 , 5 or 8 degrees. Which is correct. Using a Vacume guage and getting the vac to 18 it runs alot better now and starts with a bump of the key but after checking with a snap-on light its running at 13 degrees. Is that normal. If i set to the lower numbers it has a bad hesitation and idle. This engine is also running a Weber 38performance carb set to 3 psi of fuel and vac advance is on the port closest to the radiator.
Old 08-23-2012, 03:39 PM
Opps the port closest to valve cover has a blown diaphram if thats the port i need does anyone know where i can find a good used vacume advance or a complete oerformance dissy
Old 08-23-2012, 06:18 PM
snobdds's Avatar
For a 22r you time it by removing the vaccum advace and timing it to 0*. Then once the vaccum line for the vaccum advced is hooked up, it will be around the 8* range.
Old 08-24-2012, 06:13 AM
Yes you can set base to 0 then hook up the one port on dissy to take it to 8 then the second port to carb. Heres the thing my carb only has one vac port to hook to so i have to leave other capped off no place to put it
Old 08-24-2012, 06:25 PM
abecedarian's Avatar
should have one port from the carb and one from the manifold, no?
Old 09-13-2012, 09:44 AM
4x4jeffyota's Avatar
sorry to thread jack but I have a question. Im currently battleing a timing issue. When I plug the vacuum lines from the distributor I set timing to ''0'' and then reconnect the lines but timing doesnt move. Whats up with that? Should I replace distributor and vacuum advance?
icentropy
09-16-2020 02:47 PM
smiley52
07-11-2015 05:16 AM
nick b
07-11-2015 04:38 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: lets talk 22r timing
