Knock Sensor, with no code?
Is it possible to have knock sensor problems without triggering a CEL or code? it seems like the timing is retarding badly when accelerating and while cruising on the highway. I did the HG's and everything else including TPS, but did not replace the knock sensor; which I did spill coolant on haha.
Is it possible for a knock sensor to "partially" function?
Short answer = No. It would definitely throw a code. It's not possible to test it, so in order to know when it's malfunctioning there must be a way for the ECM to diagnose it's functionallity for you. Hence the codes.
However...
http://autoshop101.com/forms/h40.pdf
However...
However...
However...
wait...I thought the knock sensor was a detonation sensor. sensing when each cylinder was firing. or is it a knock sensor that senses the bad kind of engine knock? I just did a rebuild because I had a rod knock.
yes... it senses for knock ( more specifically a sound in a certain frequency range) so if there is something rattling around, causing sound in that specific frequency range, the KS will do what its supposed to do... retard timing. U can confirm this, by hooking up a timing light, watch the mark, then have a buddy bang on the motor with a hammer (dont go all hulk hogan on it) and watch the timing marks retard....
Oh... and no the sensor would not cause a "cel" in this case, as it is doing its job, which is to retard the timing in the event of a knock/detonation/pre-ignition/ping
rjtrials
08-06-2015 07:25 PM
accelerating, bad, code, codes, detonation, drivetrain, knock, knocking, sensor, short, throwing, timing, trigger, unbalanced, vibrations
