ISR Mod on 3VZ-E?
ISR Mod on 3VZ-E?
Hi there,
Can the ISR mod be performed on the 3.0 3VZ-E engine. I've done a search and only found info on the 22R-E and 5VZ-E engines.
I took the module off and had a look at it and it just appears to be a plastic box with a 90 degree turn it it.
Any help will be appreciated.
Adam
Adam
I stand corrected. I only searched on here and didn't find. However, when you google it(as you kindly supplied) it throws up a thread, from here of all places. I guess the google search has more slack than the forum search.
So, thanks.
So, thanks.
It is odd isn't it? Why the terms ISR mod 3VZ-E don't give you much using the search feature. As far as threads or posts are concerned. Yet if you click on Web & Images for those same terms, you get much better results. As far as what you were looking for, that is.
TheBFA
02-15-2020 06:55 AM
voiddweller
53
02-01-2016 05:46 AM
