Installing SR5 clock in my pickup. help
Old 07-21-2012, 09:52 AM
Wheelindealin's Avatar
Ok i have a 93 pickup. Its baseline manual everything. I picked up a free oem dash clock out of a 4 runner today and was wondering how i could hook it up and get it to work. I have the plug for the back with about 5in of wire on it.
Has anyone done this and know how? The plug has 4 wires i think.
Any help would be great
Old 08-07-2012, 10:09 PM
4Crawler's Avatar
See if you can find a Factory Service Manual (FSM) for as close to the year of the donor vehicle for the clock and look up the wire colors in the wiring diagram. 4 wires are typically constant 12 volts for the actual clock, 12 volts for the display, ground and a a dimmer wire that dims the display at night.
Old 08-08-2012, 06:35 AM
James Woods's Avatar
My truck is the same way, base everything, manual steering and all. I swapped over to a clock and the plug was already back there so all I had to do is untape the plug and install the clock.
Old 08-08-2012, 08:28 AM
Fink's Avatar
Moved to the 86-95 Trucks & 4Runners section. Was originally posted in Computer Talk.
Fink
Old 08-08-2012, 08:37 AM
myyota's Avatar
Your truck should already have the plug for the clock, just locate it and plug it in. I have installed clocks in several truck that never had them.
Old 08-08-2012, 12:59 PM
arlindsay1992's Avatar
With or without a factory clock, the harness and plug is there. Usually the factory covers it with a bit of electrical tape. Take off the tape, plug in the clock, punch out the blank that goes where your clock goes, done.
Old 08-08-2012, 02:49 PM
Discombobulated's Avatar
what year 4 runner did the clock come out of? And yes it is very easy as said above.
Old 01-25-2013, 05:11 PM
CAdot's Avatar
Old 01-25-2013, 06:03 PM
4Crawler's Avatar
Likely do not need to connect the dimmer wire, that just dims the display when the headlights are on. I think that is one of the wires that go to 12 volts (or it may be ground) when the lights are on, likely the radio has such a wire running to it. Try w/o connecting that wire and if it is OK, run as-is. If it is too bright at night, you could tie the dimmer wire to 12 volts and see if that works OK (might be too dim during the day). If that does not work, find a wire that goes hot with the lights on.
Old 01-25-2013, 06:18 PM
CAdot's Avatar
Old 01-25-2013, 06:53 PM
4Crawler's Avatar
Originally Posted by CAdot
would 3amp inline fuse be too low?
here is a thread i started in the honda forum.
http://honda-tech.com/showthread.php...1#post48381876
it has pictures and a wiring diagram for this clock. however, i am a little confused because my clock is an analog clock. how will an analog clock keep time if it is powered by an ignition wire without a constant power source? did analog clocks back in old cars tick even when the car was totally off?
Usually those need constant power, just like the digital clocks. The digital clocks usually have additional connections for switched power to run the display and then the dimmer wire to dim the display at night. The analog clock usually has constant 12 volts to run it (3 amp fuse is plenty) and if it has a back light, then a wire for that. And yep, in the good old days, the analog clocks ticked away 24/7, they only pull a milli-amp or so of current.
Old 01-27-2013, 11:44 AM
CAdot's Avatar
Old 01-27-2013, 12:29 PM
CAdot's Avatar
Old 01-27-2013, 03:44 PM
Co_94_PU's Avatar
i figured it out. took the clock apart and traced the wires. here is the correct 1984 honda accord analog clock wiring.
top left is - panel lights power
top middle is - GROUND
bottom left is - dimmer input
bottom right is - CONSTANT POWER
thanks yotatech, peace
You need to point out if your looking at the wiring side or accessory. or it gets confusing. Assuming you're looking at the clock not the plug thats about right for the generic toyota clock.
Where is our pictures
Old 01-27-2013, 04:17 PM
CAdot's Avatar
Old 01-29-2013, 07:13 PM
maco35's Avatar
Clock looks factory, and the truck looks super clean.
Old 01-29-2013, 08:12 PM
Co_94_PU's Avatar
Yeah nice factory look to that clock, can't tell if it had a different face plate for the truck(rear mount) vs car(front mount).
Just an offhand comment too. I think you typoed in your first post. Isn't that an 83 dlx model? Faux wood dash, chrome trim, dlx/sr5 cluster, additional lower guages? I'd reallly hate to think I missed out on the nicer dash layout by just one year I mean it was still ok to be a smoker and have crap on the dash back then.
I got no junk drawer on my dash and the ashtray might as well be on the floor. WHAA!
Old 01-31-2013, 06:44 PM
CAdot's Avatar
Old 01-31-2013, 06:54 PM
CAdot's Avatar
MO transplant
04-23-2023 11:58 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
Massmayhem247
07-24-2015 12:07 PM
Rkellerman
07-12-2015 08:42 AM
Quick Reply: Installing SR5 clock in my pickup. help
