Im having over heating in my 91 4runner 3l v6. what are possible problems?
Old 07-29-2009, 04:43 PM
chaltig's Avatar
My 4runner is overheating pretty bad. i had the head gasket replace last year and just replaced the thermostat. It over heats, or says its over heating, when I'm stopped, but while driving it runs just fine? any suggestions?
Old 07-29-2009, 04:46 PM
Jay351's Avatar
check your fan clutch...
Old 07-31-2009, 09:38 PM
chaltig's Avatar
its good
Old 07-31-2009, 10:24 PM
Jay351's Avatar
Is your water pump good, is your coolant old and cruddy?
Do you have a fan shroud?
You sure you put the right thermostat in??? What kind?
Old 07-31-2009, 11:11 PM
Sponsor
Tofer's Avatar
Old 08-01-2009, 12:11 AM
mick cassidy's Avatar
is your idle @ 800-1000 rpm , also try to flush your cooling system i yse white vinegar it breake up water deposits you need to learn the back flush technique disconnect the top rad hose and have the garden hose to the intake of the rad. truck running takes about 20 mins then drain and mix 50 50 coolant if your still having heating issues check timing , check the rad if you see crud in the rad. try to switch to a alum one fan and shroud will cause problems thats it for a cooling system its pretty basic
Old 08-04-2009, 05:47 AM
chaltig's Avatar
yeah it was a bad rad and thermostat.
alexcarey
10-14-2015 06:05 PM
dzldust
7
10-06-2015 05:39 AM
Flightguy
10-02-2015 05:34 PM
Jdgarrison
10-01-2015 05:22 PM
JookUpVandetti
09-30-2015 08:58 AM
Quick Reply: Im having over heating in my 91 4runner 3l v6. what are possible problems?
