ignition coil interchangeability
Old 08-21-2011, 05:08 PM
brysawn's Avatar
I've got a 86 pickup that I believe to have a bad ignition igniter, but when I went to remove the one from my 94 pickup, I noticed they were different. Can they be used between each other, with or without the coil?
Old 08-21-2011, 05:17 PM
bone collector's Avatar
what motors are in the 2 trucks?
Old 08-21-2011, 05:28 PM
myyota's Avatar
The ignitor and the coil are two seperate parts, so you need to figure out which one is bad. The coil is a cheap part to buy, but the ignitor can be very expensive.
Old 08-21-2011, 05:29 PM
brysawn's Avatar
Oh man, I can't believe I forgot to put that. They are both 22re's
Old 08-21-2011, 05:30 PM
brysawn's Avatar
The igniter is bad. But I noticed that the one on my 94 has a different number on it then the one on my 86. I'm assuming they can't be changed
Old 08-21-2011, 05:32 PM
myyota's Avatar
The ignitors are probably the same, but the plugs will be diferent
Old 08-21-2011, 05:36 PM
myyota's Avatar
I have read on here, were people have unsoldered the plugs from a diferent ignitor and soldered the plugs from there bad ignitor onto the new one and it worked. All you can do is try it, it might work.
Old 08-21-2011, 08:38 PM
brysawn's Avatar
Yeah I can see that. But for that much work I might as well just buy a new one
MadMax48
03-03-2020 10:33 AM
mojo4x420
09-16-2015 08:07 AM
JHalcyonM
09-14-2015 01:10 AM
icentropy
09-10-2015 05:03 AM
Quick Reply: ignition coil interchangeability
