idle problems
idle problems
on my 88 4runner When i crank up it idles fine so when I am driving and let off the gas lets say at a stoplight I am idling really high but if I tap the gas the idle drops back down to normal. I though my throttle cable was sticking but was good. I changed all my vacuum caps and made sure all my hoses were good and cant find the problem? any advice would be appreciated.
Staff
That sounds like your Dashpot is sticky. I have experienced that several times. Sometimes lubing it will help. It is located just beneath where the Throttle Cable hooks to the Throttle Body. There is a Plunger with a black/brown rubber boot, accordion style cover that gets sticky. You may be better off just replacing it.
