idle problem with 22re
alright well i have a problem with my 22re (206,600 miles) whenever im sitting at a light or something my truck sits a rattles everything in the truck...like a lot but once i get going it stops or when i have my foot on the gas a little it stops too...what could the problem be?
-thanks
-thanks
the engine mounts are good and everything but i guess it might be the plugs and whatnot cause i sunk my engine underwater like a month or two ago...so i should probally pull and clean those or something.
i have the same problem and replaced everything u listed, my uncle is a mechanic and has his own shop, www.rosevillerodandcustom.com but anyways he went over it and the 4th cylinder on mine is running rich and he thinks the injector is bad and i have a really rough idle but once u give it power it smooths out so sounds like an injector
yeah im going to go through and probally change everything cause my truck is starting to overheat too but thats probally radiator fluid that i need to change
steve miller
10-10-2015 01:40 AM
Jnkml
07-06-2015 01:20 PM
