idle drops after reving the motor
hey been lurking for awhile. 93 sr5 4runner. i hit the gas real quick and the tach drops to 500 or less. then raise back to 1000.some times it dies. only when its hot. any ideas to where to start the search.
When my 22re was doing this it was a dirty and leaking intake. Take it off and clean it and replace the gaskets. I found the famous black goo inside. Now it never happens anymore. Mine would only die if I was over 3 grand and then just pushed in the clutch and let it fall to idle. It was too clogged to compensate with enough air around the throtle plate to keep it running.
Jnkml
07-06-2015 01:20 PM
