IAC Gasket Question
IAC Gasket Question
I was taking apart my TB and IAC to clean them, working on the surging idle. and i tried to take off this gasket, which broke on me, its on the left side of the IAC with the 4 screws
I was trying to find out where to get another one..
and i had a question about whats behind it...
something to do with coolant flow? was going to take that out and clean it also.
Ive been looking browsing the forums/interweb for the gasket but found nothing.
I have a 89 22re Pickup
Im new to toyota's this is my first one!!
Thanks guys,
Thanks guys,
Ive Looked online for the gasket. but no luck, Dealership probably and arm and a leg, havent checked them out though, maybe ill try your "coolant friendly gasket material." solution. What about the deal inside of it? is that the valve part?
The Gasket is still on the IAC in the 2nd picture nothing is broken on. it just needs to be clean. is it okay to take the valve part that has to 2 slots on each side? To clean it?
On the throttle body the flap inside, should you see any light through the other side?
i found a thread somewhere about it but i cant remember where at.. Doh!
the1998sr5
15
07-14-2020 08:35 PM
