I cant get these windows to work help me!!!
none of my windows how power.
none of my windows will move or wiggle even
no power at anything
no power to my moonroof relay
all my fuses are good and all have power in and out
im taking it to a mechanic if i cant get this i have on last post. please help
even if that is unplugged would it make it have no power to my sunroof or my back window.
and even if its locked would it do that to the sunroof or back window. same question lol
which switch are you asking about
the power lockout I am referring to would affect the back window.
the drivers side master switch is right next to it correct? that is the one I believe Mr Peepers is referring to.
Pop out that drivers side switch pod and I believe something is loose or unplugged, let us know if we are full of it.
Test the switch. Use an ohm meter and the 1993 FSM posted in the sticky.
This isnt a hard problem, just gonna take some time to trace wires and test all your switches and whatnot.
Switch is bad or perhaps there is a bad spot in the main power wire?? Refer to the FSM for more info... If you had a real one in hand, you could use the nice electrical diagrams..
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
