How bad of a job-replacing rear pinion bearing?
Started getting some clunk in the rear driveline, thought it was u-joints but after some inspection there is some play in the rear pinion. Dangit. Anyways, just want some insight on how bad of a job this is? Haven't done a Toy 3rd before.
the third is a cake walk to get out. i would look at zuks site to see what your getting into hes got some great links for you to get some help on www.gearinstalls.com
It's not toooooo bad, granted you have a press to remove/install the new races.
Other then that, it's just a matter of the normal setup on the gears.. which happens to be pretty simple with the way Toyota has things set up. (adjustments, that is)
Oh, and make sure you know what kit you are getting. The 4 and 6 cylinder differentials have different pinion bearings..
Hmmm...after doing some reading I can see I have the capabilities in the shop to do it. However I'm looking at it from a time/money perspective and not knowing the condition of the gears or side bearings that's got me thinking I'd be better off looking for another 3rd. Running stock 4.10 gears, wouldn't be a bad idea to goto 4.56.
Already ordered axle seals, some brake components, u-joints...figure I'll make a day of it.
The only thing I'm debating is switching from 4.10 to 4.56. It's my daily driver and in the winter I run stock size snow/ice tires so 4.10 is fine. But in the summer I throw on 31's and it does lose some performance. Obviously I have the cost of the front as well so that almost doubles the price...
think I'll stick with 4.10.
I have 31's with 4.10's. gotta mash it on the freeway more than I like didnt before the 31's. Gotten used to it and gas is still around 20mpg or more on average depending on conditions, where im going etc etc
ill be doing 33's and 5.29's this spring tho.
I think you'd like the 4.56's a lot.
jerusry
10-19-2015 05:28 PM
icentropy
07-09-2015 02:12 PM
