Highbeams won't work
Old 03-12-2017, 06:46 PM
Zach_trun's Avatar
93 reg cab pickup, low beams work fine, high beams will flash when the lever is pulled towards driver, but when I push the lever forward to keep the, on, they won't turn on...... what should I check first to try and so,ve his issue? Thanks in advance
Old 03-12-2017, 06:56 PM
L5wolvesf's Avatar
Sounds like the switch to me.
Old 03-13-2017, 12:07 AM
RAD4Runner's Avatar
Second that.
Zach_trun
Turn headlights on. Make sure low beams come on.
Switch to high beam. Still no light, of course?
Find Pins 5 (Red-Yel Wire) and 13 (wht-blk) of dimmer combo switch . Jump 5 to 13. Got highs?
If you get high beam, it's bad contact between those 2 pins. You may be able to clean or fix. However, the flaw in headlight wiring of that generation where current flows on thin wire over a convoluted path (ask 4crawler) and though the dimmer-combo switch will shorten it's life again.
If you still don't get highs, jump pin 5 directly to shiny, bare metal ground. Got highs? If yes, it's bad connection between pin 13 and ground.
Old 03-13-2017, 08:55 AM
Fossilized
Staff
dropzone's Avatar
Rad4Runner as always thorough as heck
x3 on your switch
to replace,
disconnect battery
pull steering wheel,
remove column cover
disconnect multi pin connector (usually bolted under the steering column)
pull switch,
replace and repeat
you may find there is a difference between the combo switch for a tilt column and non tilt
Old 03-13-2017, 10:01 AM
RAD4Runner's Avatar
...pull steering wheel...
Thanks, Robb.
I have not actually done the dimmer-combo switch myself, I do not know if the test points are accessible for troubleshooting before pulling the steering wheel.
Old 03-13-2017, 10:57 AM
4runner4us's Avatar
Check 4crawlers website, not sure if it applies to a 93 but cleaning the contacts as he shows, worked for my 89.
Old 03-13-2017, 03:03 PM
wallytoo's Avatar
cleaning the contacts works on multiple toyota vehicles. cleaned them on my '87 4r (and added an H4 harness/relay), and cleaned them on my '91 celica, which is harder, because there is an airbag in the steering wheel pad to deal with.
wally
Old 03-13-2017, 04:19 PM
RAD4Runner's Avatar
Originally Posted by wallytoo
... added an H4 harness/relay...
+1
Conversion harness is essential for brightness and extending the life of the dimmer-combo switch.
Old 03-13-2017, 05:20 PM
L5wolvesf's Avatar
X2 on that always good info from R4R :
Old 03-13-2017, 05:30 PM
RAD4Runner's Avatar
Tnx
Old 03-14-2017, 02:50 AM
wyoming9's Avatar
Red face
The sad fact is quite a few can`t look at the print and then look at the plug/ harness and have a good understanding of both
Then Toyota Schematics are some of the most simple to understand compared to what I need to work with.
Good job as always
