high idle and tap tap tap.....boom?
Old 03-29-2010, 11:51 AM
osamabinkeifen's Avatar
just got the runner running and it sounds like poopoo.
also idles has after warm.... maybe because of headers?
does that sound like i need to reshim the valves? or does that just sound like fuel injectors?
her new name is money bags officially!
Old 03-29-2010, 11:53 AM
oh yeah and the exhaust smells reallllllly rich......
Old 03-29-2010, 12:20 PM
Lumpy's Avatar
Mine was doing that when I first got it...then I hydro-locked it. I believe it's your valves making this noise. Seems like it in mine, when i locked it she really started ticking. Now it's not rapping like a rod bearing, I have a parts truck that does that. This seems more like a valve sticking, I have not had a chance to tear into her yet.
Old 04-08-2010, 11:15 PM
norcal707's Avatar
hey I have the same clicking noise...can it be the injectors or valves?
Old 04-08-2010, 11:50 PM
hunter4runner's Avatar
that sounds like youre due for a valve adjustment, thats more than just the normal tick for either valves of injectors
Old 04-09-2010, 04:39 AM
norcal707's Avatar
how bad is it for the engine if you dont get the valve adjustment it right away.....my local dealer want $500 to adjust the valve but dont have the money right now.
Old 04-10-2010, 12:58 PM
almost all my valves were tighter than spec... so im hoping that's what the noise was from! just waiting on the valve adjustment tool to get here(ups is slow BTW). nor cal if you let the ticking go u may have a chance at burning a valve, that's the reason i had to get a head job...sucks and is way expensive!! i couldnt imagine what a shop would charge in labor to pull your heads!
Old 04-10-2010, 03:24 PM
norcal707's Avatar
Well I ran the 4runner for less that a day and blown the head gasket againg....I am selling, ig I don't sell it then I going to rebuilt the whole engine.
Old 04-13-2010, 04:58 PM
annoyingrob's Avatar
A $10 set of feeler gauges, a 12mm wrench, and a flathead screwdriver are all that are needed to adjust valves. You can do it yourself in about 30 minutes. It's quite easy.
Old 04-13-2010, 05:27 PM
pruney81's Avatar
Probably valves and/or injectors, doesn't sound that bad to me
Old 04-13-2010, 07:45 PM
so i finally got the valve tool in on monday night so ive been working on it today. i was able to change around shims and get all but 2 valves within spec! on the passenger side all the exhaust valves were too tight and the intakes were too loose and only 2 were outta spec on teh driver side. crazzzzy! i couldnt even get a .002in feeler in most of the tight ones! so running to the stealer again tomorrow....i pray they have these in stock!
Old 04-13-2010, 07:49 PM
for first timmers ummmm maybe more like 3 hrs(i would include myself in that category lol)... lots of measuring writing numbers and micrometering!!!! and i believe it could be done without the valve tool but its just soo much easier with it!
Old 04-13-2010, 08:45 PM
yotaman90's Avatar
Thats only if you have a 22R
Old 04-13-2010, 09:22 PM
betelnut's Avatar
Nice job, osamabinkeifen. Hi from Austin. Wish I'd known earlier, you could've borrowed my tool.
Old 04-13-2010, 11:21 PM
norcal707's Avatar
hey osamabinkeifen, where are the pics to show us how to adjust the valves...or at least to show us how you did it...does anyone knows if there is a tread showing how to adjust the valves?
Old 04-14-2010, 03:14 AM
WatsonToyota's Avatar
try searching for it
Old 04-14-2010, 07:07 AM
norcal707's Avatar
i have...
Old 04-14-2010, 09:59 AM
allnmstkn313's Avatar
If there's no exhaust leaks, and you're not tossing any engine codes, valves would be the thing to check.
These are shimmed bucket valves, have fun adjusting em
http://myweb.dal.ca/is353832/93fsm/index.html
Old 04-14-2010, 04:49 PM
dang that would have been awesome... u wouldnt havppen to have any 2.55mm shims lying around??? i need 2 and ill be finished!
u want me to make a video or something lol?
Old 04-15-2010, 04:04 PM
Sorry, I just assume everybody has a 22R sometimes.
Quick Reply: high idle and tap tap tap.....boom?
