Help: brake light blinking on Dash
Old 04-01-2017, 04:33 AM
C.j. Scott's Avatar
I know this may not be the right section for this. My brake light on the dash keeps coming on and going off. What is that all about.
Old 04-01-2017, 04:39 AM
Fossilized
Staff
dropzone's Avatar
Helps to say what year, engine and trans type..
I added your issue to the title, 'Help' as a title can lead to your thread being deleted with out notice
Old 04-01-2017, 04:44 AM
C.j. Scott's Avatar
Thank you sir. It's an 87 4x4 with the 22re
Old 04-01-2017, 05:47 AM
k-ray's Avatar
The obvious first place to look at is the emergency brake light switch at the end of the emergency brake actuator. Maybe it just needs adjustment?
Old 04-01-2017, 06:49 AM
scope103's Avatar
Check the brake fluid level. When low, the brake light illuminates.
Old 04-01-2017, 08:26 PM
identity's Avatar
Is it the only light coming on? If your alternator is going out your brake and charge(battery) lights will both come on.
Otherwise, as has been said check brake fluid level, brake fluid level sender, and parking brake switch.
Old 04-01-2017, 09:40 PM
Nervo19's Avatar
I just made my son diagnose the dash brake light two days ago. The brake fluid was an inch down from the minimum level. In the 2000 Tacoma the light once went on and I sprayed grease on the parking brake cable and it went out.
Old 04-02-2017, 04:01 AM
RAD4Runner's Avatar
Posters Should Indicate What Truck Model-Year-Engine-Transmission
O.P.
Like mentioned above ^^
Amen!
When posters do not mention what year-model-engine-transmission they have I assume it's an Escalade - LOL!
atcfixer
01-13-2022 10:06 PM
mdwreckdiver
07-20-2017 03:31 PM
Tilikum102602
04-02-2017 12:04 AM
mrmike210
03-31-2017 05:48 PM
Joseph.from.sd
03-08-2017 01:34 PM
Quick Reply: Help: brake light blinking on Dash
