Headlight woes
Old 04-03-2008, 07:59 PM
yarosig's Avatar
Headlight woes
Here's the problem low beams work perfect, high beams only work on flash mode. I have taken apart the column and cleaned out the combo switch. I switch on brights, the light on the dash lights up, but the headlights die. I've been trying hard to fix this problem but cannot figure this one out.
Old 04-03-2008, 08:21 PM
myyota's Avatar
Helps to know what kind of truck you have ?, have you checked the headlight relay ?, they can go bad and cause the problem your having.
Old 04-03-2008, 08:24 PM
yarosig's Avatar
89 4runner 22re. Where is the relay located?
kawazx636
10-06-2021 03:03 PM
4banginRunner
11-13-2015 05:23 AM
mreagen
10-05-2015 04:27 PM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: Headlight woes
