Headlight Help!!!!
Old 01-20-2014, 03:56 PM
Tugs's Avatar
Headlight Help!!!!
My drivers side headlight on my 89 4x4 pickup is like a real dim dull yellow color when it is on high or low beam. I switched the bulbs same results so I ruled out the bad bulb. Does anyone have any suggestions? The passenger side works fine.
Old 01-20-2014, 04:28 PM
RAD4Runner's Avatar
Assuming your wiring is OK, a busted fuse on Driver's side would cause that. Side with busted fuse would not go all the way OFF but get dim.
Explained better with a schematic below.
The way Toyota wired it, when you put it in low-beam, some current (pink in schematic below) from good side will flow through the supposedly "unused" high-beam filaments of both bulbs to the filament of the side with busted fuse. Side with busted fuse will have lower voltage across it, so it will light up but dimly.
When you put it in high-beam similar thing happens, but this time "leakage" current will go through the supposedly "unused" low-beam filaments.
The supposedly unused filaments where leakage current flows through would actually glow, too but hard to notice.
Old 01-20-2014, 05:30 PM
Tugs's Avatar
Thanks I will check tomorrow this sounds like exactly what's happening I will let you know how it turns out.
Old 01-21-2014, 03:41 PM
Tugs's Avatar
RAD4Runner That was it replaced the fuse and it works now Thanks!
Old 01-21-2014, 04:53 PM
RAD4Runner's Avatar
Cool, Dude! Glad it was that simple and am happy to help.
Old 01-21-2014, 06:48 PM
My94yota's Avatar
Very cool, I was going to say a bad ground or something but thats not the first time ive seen power backfeeding like that, good call tho
kawazx636
10-06-2021 03:03 PM
4banginRunner
11-13-2015 05:23 AM
mreagen
10-05-2015 04:27 PM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: Headlight Help!!!!
