Head to Timing cover hole off. What can I do?
Hey guys. So I am building a 22RE and I put the head on and torqued it all down. However, when trying to put in the bolt that goes from the head to the top of the timing cover, either the hole is off very slightly or the gasket hole is off slightly.
Everything was put on properly so this must be a manufacturing defect (It is not off by much, just enough to stop the bolt from dropping in).
What can be done here? Drill and Tap? Again it is hard to see if the hole is off or the gasket is off because the metal looks similar but I dont want to take the head off and have to buy another gasket.
It happens to me from time to time. I take a tapered punch and put it down in there and very carefully wiggle it around to line up the holes. I do emphasize carefully!
I have always managed to line them up doing it this way
Staff
I have done similar as to what toyospearo does and basically work the bolt thru the gasket. I always keep and compare my old gasket to the new gasket. I have seen some holes not punched out in the past on other makes of cars. One kept giving me an over heating issue as a water port was not punched.
Chris Barrett
10-08-2016 07:07 PM
WildCard22RE
03-14-2016 09:52 PM
jrob4206
03-13-2016 05:00 PM
