harmonic balancer bolt
Old 04-19-2009, 11:46 AM
86OFFROADER's Avatar
i was wondering if there is an easy wasy to remove the bolt without cracking the case in front of it ... i already tryed an impact
any help would be apprecaited thanks'
its the 22re i-4
i wanna know if its left hand threads or right hand threads..it seroiuly will not move
Old 04-19-2009, 11:53 AM
874runnersr5's Avatar
what engine?
Old 04-19-2009, 11:57 AM
TOYOTA 1's Avatar
put it in 5th gear with the e brake on, and get a huge cheater bar!
or try and bust it loose with the starter(cheater bar against frame rail, put it in neutral and bump the starter), but Ive had no luck with that method.
Old 04-19-2009, 12:12 PM
mattaway's Avatar
i wouldn't recommend using the power of the engine to break it loose. too much could go wrong.
take your radiator out and you'll be able to get an impact right in there without a swivel and a bunch of extentions, they just reduce torque.
i don't know what kind of tools you have, but a wal-mart special air tool set won't do the trick.
Old 04-19-2009, 12:23 PM
abecedarian's Avatar
I've used the bar on the bolt and crank the starter method a few times with no issue. Just make sure the bar is securely pressing against the frame before spinning the engine and disconnect the coil wire from the distributor so the engine won't start.
I've also used an electric impact once or twice.
Old 04-19-2009, 12:25 PM
TOYOTA 1's Avatar
i see your point. but its not the power of the engine breaking it loose, its the power of the starter!
if you unplug the coil wire nothing would/could go wrong(unless it was operator error)
i think the op already tried the impact method.
Old 04-19-2009, 12:32 PM
if you unplug the coil wire nothing would/could go wrong(unless it was operator error)...
Imagine would could happen if the engine started, completely un-threaded the bolt, the socket / bar flop over, get caught up in a v-belt....
Old 04-19-2009, 12:38 PM
99SR5's Avatar
well my engine couldnt break mine loose, my ingersol rand couldnt break it loose. we had to take a torch and another guys gun over and over to finally get mine loose
Old 04-19-2009, 12:53 PM
TOYOTA 1's Avatar
i think the bolt/ratchet would just fall to the ground.
though i have never left the coil wire on while trying that method
Old 04-19-2009, 12:55 PM
mattaway's Avatar
^^ is how i imagined it happening, but i never thought to unplug the coil
Old 04-19-2009, 01:54 PM
crankshaft bolt
ts the 22re
i even just tryed breaking it lose with a cheater bar and i broke the socket....also i was wondering what direction the bolt is suppose to turn like left hand threads or right hand
threads i need the pulley off to change the timing chain dampner
thanks
Old 04-19-2009, 02:32 PM
You'd turn left (counter-clockwise, standard bolt rotation) to loosen. That is why they're so hard to remove- since the normal crank rotation is to the right (clockwise) it takes a bit of torque on them to keep them from loosening naturally and that is also why the breaker bar trick can be used to loosen it.
I guess someone should've suggested using an impact socket so the socket doesn't break.
Old 04-19-2009, 02:50 PM
TOYOTA 1's Avatar
i figured he had one since he already tried an impact gun
my advice would be to put some heat on it. it don't take much though so don't go getting it glowing red.
edit.. you are using a 1/2 inch impact correct?
got a 3/4 or 1" laying around
Old 04-19-2009, 03:00 PM
Hey, I'm guilty too, of not suggesting the impact socket.
And yeah, a 1/2 impact may be marginal, particularly if electric, and a 3/4 would be better suited to breaking it loose and a 1" pneumatic might break the head off if it's seized that bad.
Also, heating it up will help break any rust or whatnot loose to help let it break free more easily. Heat the head of the bolt up, but like mentioned not enough to make it glow noticibly compared to the surrounding material, then let it cool, maybe do that 2-3 times.
Old 04-19-2009, 03:08 PM
TOYOTA 1's Avatar
haha, yea you got me
atleast i didnt go down alone
Old 04-19-2009, 03:14 PM
Hehe. I try to at least be the second person to acknowledge I'm wrong, if not the first.
we're all trying to help.
Old 04-19-2009, 04:24 PM
PlugItIn's Avatar
heat it up, i just did this yesterday to break my crank bolt free. I used a 1/2 inch air impact afterwords...
Old 04-19-2009, 04:31 PM
Plumbrbob's Avatar
x2 I use heat everytime I dont even try any more without heating it up then a simple cheap impact will bust it off
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Corvoid
09-14-2015 10:10 AM
Streetrod19772000
09-10-2015 06:22 PM
Pocoyota
09-08-2015 02:41 PM
Jwp1
09-06-2015 11:03 AM
Quick Reply: harmonic balancer bolt
