hard to start - 10 seconds of cranking before it fires
This seems to be getting progressively worse... The truck will turn over for a good 10 or 12 seconds before it starts. It was just an issue when cold, now it happens if the truck sits for 15 minutes. I am lead to believe that fuel is somehow bleeding out of the rail.
I just did the fuel pump, pressure is good, checked the timing, ignitor and coil were tested and solid... Im not making assumptions about anything else, even though this is a new rebuild and almost everything has been replaced.
Could my injectors be an issue? Any other suggestions where to look?
Thanks
Thanks
I did the engine rebuild last spring and there were cold start issues, the cold start injector was cleaned and tested then, but the other 4 injectors werent touched.
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
jmc88runner
06-18-2015 03:39 PM
