grinding into reverse
sp ive had this problem a while and its just drivin me insane! whenever i go to shift into reverse, as im goin down theres a grinding of gears, no im NOT moving and rpms are NOT up. it weird, sometimes it does it and sometimes it doesnt. anyone?
Going to reverse sometimes sucks
MIne will do that once in a while. I usually push the clutch twice and it won't do it, or you might try going into first then reverse.
k thanks ill try that for sure. as i was puttin my new battery in i noticed this stray wire
<a href="http://s296.photobucket.com/albums/mm188/TomkiRider/?action=view¤t=yotawire.jpg" target="_blank"><img src="http://i296.photobucket.com/albums/mm188/TomkiRider/yotawire.jpg" border="0" alt="Photobucket"></a>
anyone know what this is? if ya need to know where its comin from ill go take a pic im not good at explainin
Thats true, I had replaced mine with the marlin unit. It fixed alot of problems, but not the grinding in reverse. Alot of yota's I have driven had this problem... Just wear and tear I suppose..
1 Post
mine grinds then jumps and the tyres bark maybe i should stop going into rev at 35mph?
ok thats was a funny my bad
i go 4th then rev works all the time plus its a stick shift any older car or truck in the world is going to do this unless it has a new or rebuilt trany its just the way they are lol
You have to wait for the input shaft to slow down before you can put it in reverse. If you are stopped, the output is stopped, but if the clutch is in, the input just spins for a lil bit before slowing down. Something that might help is to take the clutch out halfway when shifting into reverse.
irv
10-01-2015 09:49 PM
May-39
09-06-2015 01:05 PM
