Gauge swap
Gauge swap
Will this SR5 gauge cluster fit in my plain jane 91 pickup? If so, what gauges will work and which ones will I have to wire up?
http://www.ebay.com/itm/89-95-Toyota-truck-4runner-Speedometer-Cluster-163K-94-93-92-91-90-cable-/250975752501?pt=Motors_Car_Truck_Parts_Accessories &vxp=mtr&hash=item3a6f521135#ht_500wt_922
It will fit and everything will work but you need to get a sr5 oil pressure sensor. Make sure you install the sensor before starting the truck otherwise you will fry the cluster
i know the title in the ad has cable ..but ask the seller and be sure its a mechanical cluster because thats more and likely what you have ..electronic started in 92
Verify what year it came from FIRST. If its from 92, 93, 94, or 95, NO it WILL NOT WORK. 95 4Runners have cables, but that speedo will NOT WORK in your 91 either. It must be 89, 90, or 91.
Also, if you have a 4Cyl and its from a V6 (or vise versa) The tach will NOT WORK CORRECTLY. The 4cyl and V6 tachs are different.
Well, how bout this one? One of the pics shows writing on the cluster that says 90 4runner, 22re.
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_6786wt_768
Poncho0206
07-10-2015 06:21 PM
