gas gauge no work
Old 12-01-2009, 12:46 PM
xxxtreme22r's Avatar
gas gauge no work
Switched over to an "SR5" gauge in my 87 from what i believe was an 86 4runner. Now my fuel gauge don't work. stays to empty. I know there is at least 3/4 of a tank in there.
Would it be different pinouts, different sender?
Any ideas would be greatly appreciated. thanks.,
BTW I don't think the truck was prewired for the tach either since that's not working either.
Water temp works, and have the oil sender out for a "real" oil pressure gauge.
Old 12-01-2009, 08:04 PM
nastynate's Avatar
I've got the same issue. I've got an 88 SR5 cluster in my 85.
Fuel gauge works great with with the 85 LX cluster, but doesn't work with the SR5.
Originally Posted by yota4runna
What is that? Don't recall seeing it in my tank when I changed the pump last month.
Old 12-01-2009, 08:40 PM
cluster came out of an auto with 4cyl. gas gauge works with old unit, just swapped back to old one and gas gauge shows 1/2 tank.
Could it be an issue with carb vs efi?
As for the tach, it doesn't move at all. Which leads me to believe I am one of the unlucky ones that isn't prewired and have to run that wire from the tach diag connector to the tach screw.
Old 12-01-2009, 09:01 PM
nastynate's Avatar
There may be a difference in the wiring. The '86 and up wiring connector at the fuel tank is a 3-connector plug [at least on 4Runners]. Your '85 may be wired differently. I'm sure it can be made to work. If your '88 cluster came from a V-6 the tach will always be off with a 4-cyl.
I'm running a 4-cyl cluster for a 4-cyl engine. There are some differences in the wiring schematic, but after examining them I can't seem to find a fix for the gas gauge. It looks correct to me.
I'll crack it open again when I have a free weekend and hope that a 3rd time of trying will cause the solution to suddenly appear!
Old 12-01-2009, 09:04 PM
nastynate's Avatar
Yeah, maybe so. My '86 4Runner Deluxe worked with the '87 SR5 cluster with no mods. If your tach doesn't work, you need to run one wire:
My 4runner didn't have the diagnostic port (green plug in the picture) so I ran it to the negative side of the coil (read about it somewhere) and then to the tach connection on the back of the cluster. It worked great for 4 days and then suddenly the truck wouldn't start. After I removed the wire from the coil, it worked great. Adding the wire back caused the truck to stall out. Very odd!
Another task for a weekend
Old 12-01-2009, 10:31 PM
Teuf's Avatar
theres my gas gage, works too.http://images.ibsrv.net/ibsrv/res/sr...ilies/stir.gif
Old 12-01-2009, 10:35 PM
Teuf's Avatar
161 miles to go
Old 12-02-2009, 03:44 AM
efi to efi
carb to carb
or mixed
Old 12-02-2009, 08:18 AM
nastynate's Avatar
Originally Posted by xxxtreme22r
efi to efi
carb to carb
or mixed
EFI to EFI.
There is a small chance the truck's previous engine was a carb, but that was several owners ago. I'm not really certain, nor do I know how to determine this. Currently it's a 22re.
EDIT: errr... I assumed this was a question to me. Sorry if it was not
Old 12-02-2009, 11:00 AM
thanks, havent gotten to this yet, as I am working on the mother-in-laws chevy k1500 door handles inside and out.
Then I got to figure out why my alternator and brakes lights are on.
Old 12-03-2009, 05:01 AM
Answer: Alternator's not charging.
According to Autozone my battery and alternator are fine. Gonna take it out and have them test it today again.
Old 12-03-2009, 07:38 AM
cgeorge's Avatar
did you get your gauge cluster local or online? I've been looking for the same thing..
Old 12-03-2009, 08:06 AM
Got the cluster pretty much local. Couldn't find the exact one so I had to settle for one out of an auto efi 4runner. Besides $30 was a good deal I thought.
bigjstang
08-25-2021 12:41 AM
Cplmike
07-08-2015 08:47 PM
Jnkml
07-06-2015 01:20 PM
Steezy96yota
07-06-2015 10:00 AM
karbin
07-05-2015 11:37 PM
Quick Reply: gas gauge no work
