Fuel Line Part Numbers
I have the EPC installed and running, but can't figure out how to select my truck. I have searched here, other forums, and google and haven't been able to find the exact part numbers, or even a solid diagram.
My truck developed a leak on the hard fuel line going from the fuel tank/pump to the soft line that then leads to the filter. I started to try and patch it, and realized it would be much smarter to replace the entire line. Now that I have bed off the truck, I'm thinking I should do some preventative maintenance on all these lines. I'm trying to find out the part numbers for everything so I can be somewhat intelligent when I order the parts.
93 22RE shortcab 4x4 MT
Any ideas either:
How to select my vehicle in the old EPC japan/europe?
A good place to find part numbers?
Anyone want to just help me out?
Any ideas either:
I think you may be out of luck. Brake and fuel lines may not be available for these years trucks. Someone correct me if I am wrong. Why don't you just make your own? You can buy a roll of steel line and a flare tool way cheaper then what 1 line will cost you from the dealer.
I replaced brake and fuel lines and the fuel pump bracket two years ago. I don't have part #s but the dealer can find them w/ the VIN #. I believe the fuel pump bracket cost $125 then.
Avenged
07-09-2015 07:55 AM
Vargntucson
07-04-2015 12:15 PM
