fuel damper problems
Old 01-04-2015, 08:17 PM
dleehawaii808's Avatar
So I just replace a fuel damper on a 1990 4runner. ... and still leaking gas but even worst..shooting gas now..from the new fuel damper. The old one had a plastic cover on it with a screw in the middle... but napa game me a full metal 1 that looks like it just stight metal with no plastic cover..
Old 01-04-2015, 08:26 PM
scope103's Avatar
The plastic cover doesn't do anything.
Did you re-use the crush washers? If so, that's almost certainly the cause of your leak (they are one-time-use items).
If you are using an after-market replacement, you do need to check that it fits correctly.
Old 01-04-2015, 08:37 PM
Is the after market peace all metal .. I got it from napa..but ya I took off the old lost the screw when taking off the plastic cover on the old one... Replaced it with the new one and it still leaks and I got dat washer in there 2...
Old 01-04-2015, 08:39 PM
It might me dat washer den... I reused da same one...
Old 01-04-2015, 08:42 PM
I went through hell and back doing all that ˟˟˟˟ today put it all back together and leaked even worst..gas shoots out da damper. now... now gota take apart... again and get dat washer out...what a bitch
jbv808
08-06-2021 04:47 PM
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
gary4runner
09-24-2015 12:53 AM
shisha1999
07-13-2015 11:09 PM
Quick Reply: fuel damper problems
