Flywheel bolts: reusable? Loctite?
Yes, you can re use them. You only need locktite (type 242 or equivilant) for the Straight Screw Plug, Shift Lever Housing Set Bolt, and Front Bearing Retainer set bolt, which you won't be touching. I would maybe just put some anti-seize on the threads.
hiluxinargentina
09-30-2015 05:51 PM
sonorn67
09-19-2015 05:39 PM
